[osgeo4w-dev] Clash between GDAL and netCDF4 on Windows
Derek Hohls
dhohls at csir.co.za
Mon Aug 27 05:01:16 PDT 2012
Hi
I am hoping some one can help with this.
I have a "vanilla" Windows XP, into which I have installed the latest version of OSGeo4W. I then used the "register-python" script (http://code.google.com/p/maphew/source/browse/register-python/register-python.py) to make the OSGeo4W the system Python. I then installed the NetCDF4 package (available in binary form from http://www.lfd.uci.edu/~gohlke/pythonlibs/#netcdf4). Now I can import one or the other but not both packages into Python.
GDAL first:
>>> import gdal
>>> import netCDF4
File "", line 1, in
ImportError: DLL load failed: The specified procedure could not be found.
NetCDF first:
>>> import netCDF4
>>> import gdal
File "", line 1, in
File "C:\OSGeo4W\apps\Python27\lib\site-packages\gdal.py", line 2, in
from osgeo.gdal import deprecation_warn
File "C:\OSGeo4W\apps\Python27\lib\site-packages\osgeo\__init__.py", line 21,
in
_gdal = swig_import_helper()
File "C:\OSGeo4W\apps\Python27\lib\site-packages\osgeo\__init__.py", line 17,
in swig_import_helper
_mod = imp.load_module('_gdal', fp, pathname, description)
If anyone can suggest how to resolve this in a straightforward manner (i.e. without doing builds-from-scratch, and just using standard installers - I need these as part of another install, which will be aimed at a much wider, non-programming audience), I'd appreciate it.
Thanks
Derek
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean.
Please consider the environment before printing this email.
More information about the osgeo4w-dev
