[osgeo4w-dev] msys update
Matt Wilkie matt.wilkie at gov.yk.ca
Wed Feb 8 17:29:56 EST 2012
Hi Martin,
Thanks for updating the msys package, and doubly, no /triply /so, for
keeping such good notes! (http://trac.osgeo.org/osgeo4w/wiki/pkg-msys)
`apps\msys\msys.bat` could be simplified a little bit by changing lines
13-16 inclusive as they just duplicate what o4w_env.bat always does
anyway. This also enables msys to be portable.
    rem source OSGeo4W changes
    call "~dp0\..\..\bin\o4w_env.bat
And in `postinstall\msys.bat` setting the window property for the menu
and desktop shortcuts to 7 (minimized) will stop the console window
flicker on startup:
    xxmklink ... "msys" *7* "%OSGEO4W_ROOT%\apps\msys\m.ico"
(and if you took the first suggestion, the txtreplace line can also be
removed).
If you add 'maintainer: MartinLanda" to the `setup.hint` file the
package vesions page will show your name and link trac homepage
automatically (http://download.osgeo.org/osgeo4w/versions.html).
cheers and thanks again,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20120208/8c961bfd/attachment.html
More information about the osgeo4w-dev mailing list
