[osgeo4w-dev] Re: [osgeo4w] #267: ctypes version conflict with numpy
OSGeo4W trac_osgeo4w at osgeo.org
Fri Feb 17 12:47:05 EST 2012
Reporter:  davidfawcett  |       Owner:  osgeo4w-dev@…
    Type:  defect        |      Status:  new
Priority:  major         |   Component:  Package
 Version:                |    Keywords:  python ctypes numpy
Old description:
> When I try to import numpy, I get the below error.  It appears that it
> looks for ctypeslib.py in the right spot, but then it goes to the path
> for my 'system python', which is Python 2.5 for ctypes\__init__.py.
> I just ran the OSGeo4W installer to update all of the packages.
> GDAL 1.8.1, released 2011/07/09
> H:\>python
> Python 2.7.2 (default, Jun 12 2011, 15:08:59) [MSC v.1500 32 bit (Intel)]
> on win
> 32
> Type "help", "copyright", "credits" or "license" for more information.
> >>> import numpy
> Traceback (most recent call last):
>   File "<stdin>", line 1, in <module>
>   File "C:\OSGeo4W\apps\Python27\lib\site-packages\numpy\__init__.py",
> line 154,
>  in <module>
>     import ctypeslib
>   File "C:\OSGeo4W\apps\Python27\lib\site-packages\numpy\ctypeslib.py",
> line 60,
>  in <module>
>     import ctypes
>   File "D:\Python25\lib\ctypes\__init__.py", line 20, in <module>
>     raise Exception, ("Version number mismatch", __version__,
> _ctypes_version)
> Exception: ('Version number mismatch', '1.0.2', '1.1.0')
New description:
 looks for ctypeslib.py in the right spot, but then it goes to the path for
 H:\>python
 on win32
 >>> import numpy
 line 154,
  in <module>
     import ctypeslib
 line 60,
  in <module>
     import ctypes
 _ctypes_version)
Comment(by maphew):
 David, the system python variables needs to be removed from the
 environment before starting the o4w python. To see the existing python
 env, open a command prompt and type:
 set |findstr /i "python"
 If you see something like the below you'll have a conflict with the
 Osgeo4W python:
 Path=C:\Python26;C:\Python26\Scripts;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\sysWOW64
 PYTHONHOME=C:\Python26
 PYTHONPATH=C:\Python26;C:\Python26\Lib;C:\Python26\DLLs
 To fix this you'll need to remove the existing python settings from the
 system default (''[Winkey]-[pause/break] > Advanced > Environment'') or
 take care to always start python from inside a new shell which resets
 those variables, e.g. from a batch file:
 @echo off
 set PYTHONHOME=
 set PYTHONPATH=
 set
 PATH=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\sysWOW64;
 call c:\osgeo4w\osgeo4w.bat
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/267#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
