[osgeo4w-dev] Re: [osgeo4w] #272: osgeo4w - PROJ.4 strings do not
work with GDAL
trac_osgeo4w at osgeo.org
Thu Feb 23 15:02:37 EST 2012
#272: osgeo4w - PROJ.4 strings do not work with GDAL
Reporter: tcgeophysics | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: major | Component: Package
Version: | Resolution: fixed
Keywords: |
Changes (by tcgeophysics):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:1 jef]:
> try quotes:
> gdalwarp -t_srs "+proj=utm +zone=11 +datum=WGS84" input.tif
output_utm11.tif
I did not think about that syntax issue as simple quote are used in
examples on the gdalwarp manual page.
Double quotes work perfectly!
Thanks
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/272#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
