[osgeo4w-dev] Re: [osgeo4w] #274: Problem with installation of OSGeo4W
OSGeo4W trac_osgeo4w at osgeo.org
Wed Feb 29 13:16:54 EST 2012
Reporter:  frman18  |       Owner:  osgeo4w-dev@…
    Type:  defect   |      Status:  new
Priority:  major    |   Component:  Installer
 Version:           |    Keywords:
Comment(by maphew):
 This sounds similar to #264 and could be an issue with a local proxy
 server (Express doesn't use proxy settings). Try using Advanced install
 and see if that helps.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/274#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
