[osgeo4w-dev] [osgeo4w] #294: Recoding non-Latin characters with GDAL is not supported now.
trac_osgeo4w at osgeo.org
Mon Jun 25 04:16:31 PDT 2012
Reporter: akaginch | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: character recoding
The encoding of Shapefile has been supported in GDAL since 1.9, but it is
not enabled because iconv library is not linked yet. Therefore, non-Latin
language users sometimes have troubles.
For example, when I convert a dataset of Shapefile that dbf file has "19"
value (it means "CP932") in LDID field to KML format with ogr2ogr, the
following message is shown.
Warning1: Recode from CP932 to UTF-8 not supported, treated as ISO8859-1
to UTF-8
The Japanese characters of generated KML file is incorrect because of
wrong recoding that this message says. I think this also results character
corruption in QGIS as below.
[http://hub.qgis.org/issues/5255 Quantum GIS Desktop - Bug #5255: Wrong
codepage of shapefile - QGIS Issue Tracking]
Would you please configure the packages including GDAL with iconv library
and make the benefit by version-up come off?
Best regards.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/294>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
