[osgeo4w-dev] [osgeo4w] #278: apt remove or upgrade fails on
read-only files
trac_osgeo4w at osgeo.org
Fri Mar 23 14:20:00 EDT 2012
#278: apt remove or upgrade fails on read-only files
Reporter: maphew | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: pkg-apt
C:\> apt remove msys
...snip
File "<string>", line 1043, in <module>
File "<string>", line 326, in upgrade
File "<string>", line 150, in install
File "<string>", line 175, in install_next
File "<string>", line 453, in do_uninstall
WindowsError: [Error 5] Access is denied:
'B:\\o4w\\apps\\msys\\man\\cat3\\regcomp.3.txt.lnk'
Inspecting the file attributes shows it is set as Read-only. A simple
`attrib -r *.lnk` fixes it.
That said, the link files are broken anyway as they are hard coded to
`G:\Program Files\Regex\man\...`.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/278>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
