[osgeo4w-dev] [osgeo4w] #282: python path getting overwritten
trac_osgeo4w at osgeo.org
Thu Mar 29 17:40:29 PDT 2012
Reporter: lpinner | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: minor | Component: Package
Version: | Keywords:
In %OSGEO4W_ROOT%\bin\o4w_env.bat the \etc\ini\*.bat files are called in a
loop (alphabetically i presume). When %OSGEO4W_ROOT%\etc\ini\orfeotoolbox-
python.bat gets called, it sets PYTHONPATH to
%OSGEO4W_ROOT%\apps\orfeotoolbox\python. This gets overwritten when
%OSGEO4W_ROOT%\etc\ini\python.bat is called afterwards i.e. SET
PYTHONPATH=%OSGEO4W_ROOT%\apps\Python27.
This causes QGIS to report an error on startup ("Could not find the Python
bindings for OrfeoToolbox, which are required to run the this module") and
breaks the python bindings in the osgeo4w shell generally.
Perhaps these batch files should set PYTHONPATH by appending/prepending,
i.e. for etc\ini\python.bat:
SET PYTHONPATH=%PYTHONPATH%;%OSGEO4W_ROOT%\apps\Python27
or
IF "%PYTHONPATH%"=="" (
SET PYTHONPATH=%OSGEO4W_ROOT%\apps\Python27
) ELSE (
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/282>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
