[osgeo4w-dev] python packages
John Callahan john.callahan at udel.edu
Tue May 8 14:35:11 EDT 2012
Sorry if this question is trivial....  How do I view a list of the python
2.7 packages installed with OSGeo4W?    To install/remove packages, I read
that using pip should work.  (
http://trac.osgeo.org/osgeo4w/wiki/ExternalPythonPackages)  Is that still
the primary method or can pythonwin be used?
Thanks for your help.
- John
John Callahan, Research Scientist
Delaware Geological Survey, University of Delaware
URL: http://www.dgs.udel.edu
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20120508/9ff6374a/attachment.html
More information about the osgeo4w-dev mailing list
