[osgeo4w-dev] ImportError: OSGeo4W problems with Python/GDAL
Matt Wilkie
matt.wilkie at gov.yk.ca
Wed May 9 13:46:49 EDT 2012
That's interesting. Today I get the same problem Casper reported.
Yesterday I didn't; likely because I'd been running from a command shell
several days old and it didn't have my current full system path in it.
I eventually tracked it down to a certain dll in PATH, outside the
osgeo4w tree: libeay32.dll. It's part of OpenSSL. Moving that external
file elsewhere enabled python to carry on as normal.
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 08-May-2012 10:21 AM, Matt Wilkie wrote:
> Hi Casper,
> I think you'll need to start from as clean an environment as possible
> and add items to path until things break again.
> For example, from a command shell (start > run > cmd.exe):
> :: clear whole PATH
> set path=
> :: clear PYTHONPATH, PYTHONHOME
> set pythonpath=
> set pythonhome=
> :: set basic o4w environment
> cd /d c:\osgeo4w
> set osgeo4w_root=%cd%
> path=%osgeo4w_root%\bin
> Now run python and import gdal.
> If it works, from the same command shell run each bat in
> "osgeo4w\etc\ini" and test the python import again until something fails.
> If it doesn't work, something is wrong with the current o4w package
> ecosystem and we'll try and dig it out.
> If you get through all the ini bat's without error, then the problem
> lies somewhere in the host Windows environment. Likely culprits
> include things like other python directories or .dll's in PATH,
> PYTHONPATH or PYTHONHOME (not necessarily gdal dll's).
> let us know how you make out,
> matt wilkie
> Geomatics Analyst
> On 07-May-2012 11:40 PM, Casper Børgesen (CABO) wrote:
>> Hi!
>> I am new to the GDAL world and I’m struggling with installing OSGeo4W
>> to a working state.
>> I have downloaded and installed the latest edition OSGeo4W. The
>> install goes smoothly. I open the OSGeo4W Command shell and enter
>> Python. I have seen that I can test the basic Python/GDAL binding(?)
>> by entering
>> >>> from osgeo import gdal
>> This results in the following error:
>> Traceback (most recent call last):
>> File "<stdin>", line 1, in <module>
>> File
>> "C:\OSGeo4W\apps\Python27\lib\site-packages\osgeo\__init__.py", line 21,
>> in <module>
>> _gdal = swig_import_helper()
>> File
>> "C:\OSGeo4W\apps\Python27\lib\site-packages\osgeo\__init__.py", line 17,
>> in swig_import_helper
>> _mod = imp.load_module('_gdal', fp, pathname, description)
>> ImportError: DLL load failed: The operating system cannot run %1.
>> I have read that this error might indicate that the installed
>> python/gdal libraries are incompatible, but I’m wondering if my
>> OSGeo4W installation is obstructed by another installation? The
>> following three lines are added to my path by the OSGeo4W Command shell:
>> C:\OSGeo4W\bin
>> C:\OSGeo4W\\apps\msys\bin
>> C:\OSGeo4W\\apps\Python27\Scripts
>> I have searched through my system looking for gdal*.dll, but I have
>> found none located within any of the folders in my PATH.
>> What can I do to troubleshoot this problem?
>> Regards, Casper
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20120509/586a5a6c/attachment.html
More information about the osgeo4w-dev
