[osgeo4w-dev] QGIS GRASS Plugin not working
Kurt Menke
kurt at birdseyeviewgis.com
Sun May 27 12:03:32 PDT 2012
Hello,
I have a fresh install of QGIS 1.7.4 and GRASS 6.4.2. Both were installed
via the OSGeo4W express installer.
GRASS alone works fine and QGIS alone works fine. However, the QGIS GRASS
plugin fails.
I can't add GRASS vectors or rasters from pre-existing GRASS databases to
QGIS. I also can't import datasets into a new GRASS database via QGIS.
For example, when I try and add a GRASS vector layer I get this error:
Cannot get projection
Cannot run module
Command: c:/osgeo4w/apps/QGIS/./grass/modules/QGIS.g.info
info=project<br><br>
The layer itself has a defined coordinate system and the QGIS project is set
to the same coordinate system.
If I create a new GRASS Mapset it fails to import an existing dataset,
either from a loaded dataset, or via OGR. I get this error:
Cannot start module v.in.ogr
Command: c:/osgeo4w/apps/grass/GRASS--1.2/bin/v.in.ogr.exe
--interface-description
I'm running a 64 bit version of Windows 7.
Any ideas of what the fix is for this will be greatly appreciated.
Thanks
Kurt Menke
Kurt Menke, GISP
Bird's Eye View
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20120527/5c555c1c/attachment.html>
More information about the osgeo4w-dev
