[osgeo4w-dev] [osgeo4w] #307: OpenEV does not start because of Python error
trac_osgeo4w at osgeo.org
Fri Oct 12 13:10:06 PDT 2012
Reporter: jratike80 | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: major | Component: Package
Version: | Resolution: wontfix
Keywords: OpenEV |
Changes (by warmerdam):
* status: new => closed
* resolution: => wontfix
Comment:
I see the same problem, but only if I run openev.bat within
C:\OSGeo4W\bin. If I run it somewhere else, I get proper behavior. I
believe that is because if you run it from within the bin directory the
local DLLs take precidence over other special version DLLs required by
OpenEV. I don't forsee an easy way to fix this.
On that basis I'm going to tentatively close this ticket, but I'm open to
suggestions.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/307#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
