[osgeo4w-dev] How to log Osgeo4W shell stdout into a txt file?
Matt Wilkie matt.wilkie at gov.yk.ca
Thu Oct 18 14:58:53 PDT 2012
to flesh Jukka's suggestion out a little:
    /command/  *>*  /filename/        Redirect/command/  output to a file
    /command/  *2>*  /filename/        Redirect any error message into a file
    /command/  *>*  /file/A*2>*  /fileB/   Redirect output and errors to separate files
Cribbed from http://ss64.com/nt/syntax-redirection.html which has a lot
of other combinations and tricks.
cheers,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 18-Oct-2012 3:08 AM, Rahkonen Jukka wrote:
> Hi,
> If you are on Windows I guess it would be done by redirecting "2" into a file.
> ogr2ogr [......] 2>your_log_file.txt
> Use >> for appending to an existing file or otherwise is will be overwritten.
> -Jukka Rahkonen-
>> -----Alkuperäinen viesti-----
>> Lähettäjä: osgeo4w-dev-bounces at lists.osgeo.org [mailto:osgeo4w-dev-
>> bounces at lists.osgeo.org] Puolesta Pietro Rossin
>> Lähetetty: 18. lokakuuta 2012 13:03
>> Vastaanottaja: osgeo4w-dev at lists.osgeo.org
>> Aihe: [osgeo4w-dev] How to log Osgeo4W shell stdout into a txt file?
>> Hi
>> I'm facing a problem with osgeo4win shell command execution.
>> During command execution i get errors that I'll like to log into a readable
>> (text) file.
>> Is there the possibility to log the stdout of the shell?
>> Which swith/command to use?
>> Thanks
>> Pietro
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/How-
>> to-log-Osgeo4W-shell-stdout-into-a-txt-file-tp5009568.html
>> Sent from the osgeo4w-dev -- OSGeo Win32 Installer List mailing list archive
>> at Nabble.com.
>> osgeo4w-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev mailing list
