[osgeo4w-dev] [osgeo4w] #304: Make installer administrative rights elevation optional.
trac_osgeo4w at osgeo.org
Sun Oct 21 20:27:35 PDT 2012
Reporter: lpinner | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: minor | Component: Installer
Version: | Keywords:
Comment(by lpinner):
I've found a workaround! Documenting here for posterity.
@echo off
REM osgeo4w-setup-noelevation.bat
set __COMPAT_LAYER=RUNASINVOKER
start "" "osgeo4w-setup.exe"
Note: my original request remains. This installer does not need UAC
elevation by default. If someone is experienced enough to install and
configure a Windows service (such as Apache), then they're experienced
enough to know how to right click on the installer and select "Run as
administrator".
Please change the manifest to "<requestedExecutionLevel level="asInvoker"
uiAccess="false"/>"
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/304#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
