[osgeo4w-dev] [osgeo4w] #304: Make installer administrative rights elevation optional.
OSGeo4W trac_osgeo4w at osgeo.org
Sun Oct 28 02:50:26 PDT 2012
Reporter:  lpinner      |        Owner:  osgeo4w-dev@…
    Type:  enhancement  |       Status:  closed
Priority:  minor        |    Component:  Installer
 Version:               |   Resolution:  fixed
Keywords:               |
Comment(by jef):
 Replying to [comment:4 maphew]:
 > (In [1204]) close #304, change default run mode to use same permission
 level as user. If admin perms are needed, r-click and "Run as
 Administrator". I don't normally touch setup.exe, beyond my skill level,
 but this change seems straightforward and harmless. Feel free to backout
 if I've overstepped my bounds.
 Did you miss to update the package?  Anyway, done now for an other change.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/304#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
