[osgeo4w-dev] [osgeo4w] #315: Spaces in install path breaks OSGeo4W.bat
trac_osgeo4w at osgeo.org
Wed Oct 31 06:43:27 PDT 2012
Reporter: aharfoot | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: 1.0 | Keywords: batch file
If the OSGeo4W.bat command shell initialising script is run from a
location with spaces in the directory path, then it will fail. This issue
is commonly encountered when using the standalone QGIS installer (1.8.0.1)
as the default Windows install path is C:\Program Files\Quantum GIS...
The following QGIS bug report gives modifications to two of the batch
files called in the initialisation sequence (osgeo4w.bat and o-help.bat)
that appear to solve the problem.
http://hub.qgis.org/issues/5345
OSGeo4W command shell package: 1.0.0.10
OS: Windows 7 64 bit
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/315>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
