[osgeo4w-dev] Setup fails to build [SEC=UNCLASSIFIED]
Pinner, Luke
Luke.Pinner at environment.gov.au
Wed Sep 26 21:42:01 PDT 2012
As a workaround to #304 (http://trac.osgeo.org/osgeo4w/ticket/304) I'm trying to build the OSGeo4W installer with a modified manifest (<requestedExecutionLevel level="asInvoker"). I've followed the instructions in http://trac.osgeo.org/osgeo4w/wiki/SetupDevelopment and tried to build with an unmodified svn checkout of the setup source and a completely fresh cygwin with all toolchain requirements installed (I think) but I fall at the first hurdle:
$ pwd
/cygdrive/C/OSGeo4W/setup
$ ./bootstrap.sh
Running bootstrap.sh in libgetopt++
autoheader-2.68: error: AC_CONFIG_HEADERS not found in configure.in
autoheader failed
Autotool bootstrapping failed. You will need to investigate and correct
before you can develop on this source tree
I got past that by downloading a source tarball of libgetopt++ and replacing the version checked from the osgeo4w setup svn repo with it. Running bootstrap again and I get the following:
$ ./bootstrap.sh
configure.in: error: no proper invocation of AM_INIT_AUTOMAKE was found.
configure.in: You should verify that configure.in invokes AM_INIT_AUTOMAKE,
configure.in: that aclocal.m4 is present in the top-level directory,
configure.in: and that aclocal.m4 was recently regenerated (using aclocal)
Makefile.am:72: error: MINGWTARGET does not appear in AM_CONDITIONAL
Makefile.am:113: error: library used but 'RANLIB' is undefined
Makefile.am:113: The usual way to define 'RANLIB' is to add 'AC_PROG_RANLIB'
Makefile.am:113: to 'configure.in' and run 'autoconf' again.
/usr/share/automake-1.12/am/depend2.am: error: am__fastdepCC does not appear in AM_CONDITIONAL
/usr/share/automake-1.12/am/depend2.am: The usual way to define 'am__fastdepCC' is to add 'AC_PROG_CC'
/usr/share/automake-1.12/am/depend2.am: to 'configure.in' and run 'aclocal' and 'autoconf' again
/usr/share/automake-1.12/am/depend2.am: error: AMDEP does not appear in AM_CONDITIONAL
/usr/share/automake-1.12/am/depend2.am: The usual way to define 'AMDEP' is to add one of the compiler tests
/usr/share/automake-1.12/am/depend2.am: AC_PROG_CC, AC_PROG_CXX, AC_PROG_OBJC, AC_PROG_OBJCXX,
/usr/share/automake-1.12/am/depend2.am: AM_PROG_AS, AM_PROG_GCJ, AM_PROG_UPC
Makefile.am: error: C source seen but 'CC' is undefined
Makefile.am: The usual way to define 'CC' is to add 'AC_PROG_CC'
Makefile.am: to 'configure.in' and run 'autoconf' again.
/usr/share/automake-1.12/am/depend2.am: error: am__fastdepCXX does not appear in AM_CONDITIONAL
/usr/share/automake-1.12/am/depend2.am: The usual way to define 'am__fastdepCXX' is to add 'AC_PROG_CXX'
Makefile.am: error: Lex (C++) source seen but 'LEX' is undefined
Makefile.am: The usual way to define 'LEX' is to add 'AM_PROG_LEX'
Makefile.am: to 'configure.in' and run 'aclocal' and 'autoconf' again.
automake failed
Any ideas?
Regards
Luke Pinner
If you have received this transmission in error please notify us immediately by return e-mail and delete all copies. If this e-mail or any attachments have been sent to you in error, that error does not constitute waiver of any confidentiality, privilege or copyright in respect of information in the e-mail or attachments.
Please consider the environment before printing this email.
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20120927/84e79ae2/attachment.html>
More information about the osgeo4w-dev
