[osgeo4w-dev] Steps Forward for OSGeo4W
Paolo Cavallini
cavallini at faunalia.it
Thu Apr 11 04:52:13 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 11/04/2013 11:08, Jürgen E. Fischer ha scritto:
> Unfortunately the second part didn't work well. Most OSGeo4w
> projects apparently don't recognize OSGeo4W as an easy way to
> distribute windows binaries and therefore either roll their own
> packages or ignore Windows completely (and let others produce
> binaries).
Yes, I think we have a governance problem here, and OSGeo as an
organization should be more involved in it.
> GRASS and QGIS use OSGeo4W for nightly builds and also put out
> stable packages when releases occur (standalone installers are made
> from the same binaries; for QGIS, I that's true for GRASS, too).
> Most of the other packages (correcty me if I'm wrong) don't get
> that kind of attention and are behind - some even made once and
> were never touched again.
Yes, that's probably the biggest issue from the user point of view.
> I wonder how we could get (and keep) more maintainers - or the
> projects themselves - pulled into osgeo4w. Because now it
> sometimes takes begging, poking, waiting and in the end you
> sometimes eventually do it (almost) yourself (like the python 2.7
> transition) - maybe leaving optional stuff behind - also if that
> users complain ((proprietary) GDAL extensions, python-rpy).
> Having a VM with all the sources and recipes on a single machine
> from a vcs sounds like an option to make everything easier to
> maintain - not sure how that would scale - if we really got more
> maintainers. And that means we're going to put work to reproduce
> what we have instead of moving forward - not that's a bad thing,
> but maybe noteworthy.
Yes, we're basically talking about redoing a deb-like distro on
Windows. Not an easy task for sure, so cooperation and proper support
will be essential.
Again, this boils down to a governance problem, and OSGeo perceiving
osgeo4w as a crucial tool for dissemination of free GIS (far more than
promotion material IMHO).
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlFmo+wACgkQ/NedwLUzIr7jzACgoWN0tp0OtnHGolENFNywWXzl
rokAniFkHoF9Ud9KU340Ugl2mL//o5sC
=GiQt
-----END PGP SIGNATURE-----
More information about the osgeo4w-dev
