[osgeo4w-dev] [osgeo4w] #321: help needed installation of osgeo4w installer on Windows 8
trac_osgeo4w at osgeo.org
Wed Apr 17 14:14:14 PDT 2013
Reporter: uppsruthi | Owner: osgeo4w-dev@…
Type: task | Status: reopened
Priority: critical | Component: Installer
Version: | Resolution:
Keywords: win8 |
Comment(by saultdon):
Replying to [comment:3 flavour]:
> Error box has a window title of "Mount" & content of "Access is denied".
> I am running with full Admin rights and have disabled the UAC.
I'll test out the installer tonight, I have a Win8 laptop to try it on.
I found that Windows8 does something different with the user permissions
on installed programs. Lots of applications in "Program Files" had the
Users permissions set to read only. I had to allow Users ''write/full
control'' rights so that files could be updated.
If I couldn't update the permissions, then running the application as an
Administrator worked fine too.
On Windows 8, from the Metro menu (''those ugly tiles for the touchscreen
you might not have'') you can right click the application tile and then at
the bottom, the orange menu pops up and then select ''Run/Launch as
administrator'' from there.
I found having my user in the Administrators group didn't help at all
either.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/321#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
