[osgeo4w-dev] ANN: Python 2.7.4
jamesstott
jamesstott at hotmail.com
Wed Apr 24 02:11:44 PDT 2013
I am also having problems with OSGeo4W, QGIS and the OSGeo4W command line.
I also get the problem with MAXREPEAT at the command line, and QGIS will not
open, it just crashes when the splash screen says it is loading python.
If I downgrade python-core to 2.7.2-4 I can get QGIS 1.8 to open, but it
comes up with an error about sip:
Couldn't load SIP module.
Python support will be disabled.
File "", line 1, in
ImportError: No module named sip
If I try and use the OSGeo4W command line to run a script after downgrading
python, I told that there is ImportError: No module named osgeo.
How do I fix this?
View this message in context: http://osgeo-org.1560.x6.nabble.com/ANN-Python-2-7-4-tp5048404p5049306.html
Sent from the osgeo4w-dev -- OSGeo Win32 Installer List mailing list archive at Nabble.com.
More information about the osgeo4w-dev
