[osgeo4w-dev] Update to Vol 64, issue 6: 'Program too big to fit in memory' when running installer exe file in Win 7 VDI
    Ian Jones
    imjnes77 at gmail.com
    Mon Apr 29 09:56:33 PDT 2013
Hello all again,
I haven't had much of a response regarding this issue.
In case I didn't communicate this well before, the exact error I get when I
run the osgeo4w-setup.exe installer file is: 'Program too big to fit in
memory' (when dropped into the Command Line prompt). Or if I try it in
Windows 7 proper, nothing happens at all. This is in a VDI environment, VM
Ware View Client session (with 4GB RAM, 40GB space, Administrator rights).
This is a bit of a showstopper for me as I cannot move on and do what I
want to do.
If this is a genuinely new issue that no one has seen before, is someone
able to forward onto me a detailed OS requirements list for installing
OSGeo4W so that I can try and pin-point the possible restriction and check
these with my on-site support?
Or going further, if it is simply down to the size of the installer, how
easy is it to request a cut-down installer program? I need to install
OSGeo4W with Command Line Utilities - GDAL, and python.
Much appreciated,
Ian
---------- Forwarded message ----------
Date: Wed, Apr 10, 2013 at 8:27 PM
Subject: Re: osgeo4w-dev Digest, Vol 64, Issue 6
To: osgeo4w-dev at lists.osgeo.org
Hi Alex,
Thanks for replying. Yes, I have Administrator access, I have tried it with
2 different accounts and in a completely different session as well. Without
any other apps on it. The local IT guy has looked at it as well but
none-the-wiser. I have been able to install it ok to Windows 7 on a
non-virtual, normal laptop.
Regards
Ian
On 10 Apr 2013 20:00, <osgeo4w-dev-request at lists.osgeo.org> wrote:
> Send osgeo4w-dev mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         osgeo4w-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of osgeo4w-dev digest..."
> Today's Topics:
>    1. Re: Cannot install OSGeo4W in Windows 7 VDI session -
>       'Program too big to fit in memory' (Alex Mandel)
> Message: 1
> Date: Wed, 10 Apr 2013 08:55:21 -0700
> From: Alex Mandel <tech_dev at wildintellect.com>
> Subject: Re: [osgeo4w-dev] Cannot install OSGeo4W in Windows 7 VDI
>         session - 'Program too big to fit in memory'
> Message-ID: <51658B69.6080109 at wildintellect.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> On 04/10/2013 03:43 AM, Ian Jones wrote:
> > Hi all,
> > Has anyone else had the same experience? I've just downloaded the OSGeo4W
> > Installer but when I double-click the exe file to run it and attempt to
> > install it, nothing happens. If I drop it into a Command Line session, it
> > returns the above message.
> > I have 40Gb disk space, 4Gb of RAM so don't quite understand why it isn't
> > playing ball. I am trying to do this in Windows 7 Enterprise in a VM Ware
> > View Client v5.1.1.
> > Has anyone successfully got it installed to a virtual environment?
> > Much appreciated,
> > Regards,
> > Ian
> Have you tried running as Administrator?
> Virtual Environment should not be an issue.
> Thanks,
> Alex
> End of osgeo4w-dev Digest, Vol 64, Issue 6
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20130429/e5a7e2b5/attachment.html>
More information about the osgeo4w-dev
