[osgeo4w-dev] New installer (and OSGeo4W 64bit)
Tue Aug 20 11:12:15 PDT 2013
Jurgen / Steve,
I haven't followed this discussion as closely as I likely ought to have,
but I'll make a few notes:
1) I'm not particularly interested in showing free software licenses in the
OSGeo4W installer.  I'm only showing the proprietary ones because it is
required to avoid legal liability.  I am not aware of us having any
obligation to show free software licenses.  If anything I *like* the fact
that users are forced through some agree-to-license-misery for proprietary
licenses which emphasizes how lame they are and celebrates the awesomeness
of no bull free software.
2) I'm a bit dubious about md5sum's for merging same licenses into one
request, but since I'm not worried about non-free licenses it isn't an
issue for me.
3) I'd rather not use automatic pdf conversion to text.  This process only
has to be done once per package, and I'd rather have a human review the
text-ified version and ensure that its still captures the original
agreement in a reasonable form.
Best regards,
Frank
On Mon, Aug 12, 2013 at 1:18 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Steve,
> On Mon, 12. Aug 2013 at 13:25:47 -0500, Lord Flaubert Steve Ataucuri Cruz
> wrote:
> > > Also included are license files for most packages
> ($pkg-$ver-$pver.txt, but
> > > also *.pdf and *.rtf) - for free and non-free licensed packages.
> > Actually the installer only support  a txt file as a license
> Sure.  But the ECW license is in RTF and the MrSID license is in PDF.
> I suppose pdftotext and catdoc do a good enough job to produce plain text
> from
> those.
> > > As you might notice I didn't differentiate between free and non-free
> > > licenses.  And therefore there are a lot of licenses the installer will
> > > show and request to accept.
> > It wasn't the idea, the installer only will show a license for
> restrictive
> > packages , there are only three or four packages. Only few packages will
> have
> > "license" entry in "setup.ini" file, not all.
> Sure, but I feel that it somewhat belittles the free licenses.
> > > I thought the md5sum would help to identify where the same license
> applies,
> > > but I just notices that it doesn't even work for the GPL (lots of minor
> < > difference in the files).  So that would need a different approach.
>  Any
> > > thoughts?
> > I don't understand you how md5sum might help to licenses, could you
> explain
> > us in more detail way, please? or someone could give us another point of
> > view.
> Same license.  Same file content.  Same md5sum.   In that case we could
> have
> just determine which packages share the same license by md5sum and display
> each
> license only once with a list of packages that share it.
> But unfortunately the md5sums don't match in setup.ini although the
> licenses
> are virtually the same (except for the FSF address, blanks, formfeeds and
> stuff
> like that).  So that doesn't work.
> Some of the free packages don't even contain the full license text and only
> reference the well known license (e.g. available form OSI,
> http://opensource.org/licenses/).   So the current license files could be
> well
> replaced with a pointer to that site.
> Any maybe there should be another field in the setup.ini that tells us if a
> license must be explicitly accepted.
> > > More installer observations (probably at least partly already on
> Steve's
> > > todo list):
> > Thanks by your feedback I am working on it today
> > > - the license display widget doesn't resize in the installer
> > Done
> Thanks.
> > > - Line breaks don't show well
> > > - Apparently the license display is (sometimes?) truncated and shows
> junk
> > >   at the end.
> > > - It doesn't track licenses that have already been agreed to (ie. on
> > >   reinstall).
> > > - Maybe we should also store them somewhere and produce license
> shortcuts
> > >   in the program group (or just one to the directory).
> > > - How should non-text licenses (PDF, RTF) be handled?  I suppose we
> could
> > >   just convert them to .txt in regen.sh.
> > Yes I think it should be convert to .txt I dont know if it is easy to do.
> Ok, I'll do that tomorrow then.
> > > - The program group name is not configurable (ie. OSGEO4W_STARTMENU)
> multiple
> > >   OSGeo4W installs overwrite each others shortcuts.
> > > For the QGIS standalone installer I was planning to collect all the
> license
> > > files into one LICENSE.txt that is presented on install.  Maybe that's
> also
> > > an approach for the osgeo4w installer.   Collect the licenses, present
> them
> > > in a large scrollable list and allow to accept them all at once.
> > My mentor Frank told me this process had to do for each restrictive
> package
> > but it can work if you collect all licenses files into one license.
> Question is if that's a better approach for the osgeo4w installer or not.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20130820/11f5430c/attachment.html>
More information about the osgeo4w-dev mailing list
