[osgeo4w-dev] [osgeo4w] #398: Unable to connect to PostgreSQL DB in GRASS 7.0svn on Win 7
OSGeo4W trac_osgeo4w at osgeo.org
Sat Dec 14 09:18:02 PST 2013
Reporter:  GG1234  |       Owner:  osgeo4w-dev@…
    Type:  defect  |      Status:  new
Priority:  minor   |   Component:  Package
 Version:          |    Keywords:
Comment(by GG1234):
 Well, that one was short : it seems the problem arise because Win7 doesn't
 allow to create folders with an initial ".". I manually added it with a
 workaround found on "superuser.com" : put an initial AND a final "." like
 this : ".grass7." in Windows Explorer. Windows will accept it and delete
 the final dot.
 Then the PG connection commands worked fine.
 It might be usefull to add this in the osgeo4w installer ?
 Should I therfore set the ticket to fixed ?
 Thanks,
 Cev.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/398#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
