[osgeo4w-dev] [osgeo4w] #339: OSGEO4W Installer doesn't work
OSGeo4W trac_osgeo4w at osgeo.org
Fri Feb 8 11:14:50 PST 2013
Reporter:  moreno   |       Owner:  osgeo4w-dev@…
    Type:  defect   |      Status:  new
Priority:  blocker  |   Component:  Installer
 Version:           |    Keywords:  Installer OSGEO4W
Comment(by hellik):
 Frank
 Replying to [comment:7 warmerdam]:
 > What did you have to do to fix this?  It seems like it might be related
 to a problem I'm running into on one system.
 AFAIR ''All Programms -> OSGeo4W -> Setup'' called automatically elevated
 admin privileges which I had to confirm.
 now with the OSGeo4W Installer/Setup version 1.0.6-8 (visible in the
 Advanced Install), I have to do r-click >> Run as Administrator. no idea
 at the moment why this behaviour change.
 HTH
 Helmut
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/339#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
