[osgeo4w-dev] [osgeo4w] #333: Please rebuild GDAL with VC2008 instead of VC2010
trac_osgeo4w at osgeo.org
Fri Jan 11 08:10:05 PST 2013
Reporter: jmalik | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: gdal
Changes (by jmalik):
* priority: critical => major
Comment:
Thank you both for your inputs, even though it's a bad news for me...
Yes, OTB uses the GDAL C++ API.
I originally understood the C-API approach as "if i use gdal C API, then
an application built for gdal 1.9.1 will work without rebuild with a gdal
1.9.2 build; if using the C++ API, then I must recompile the app each time
gdal is rebuilt".
Guess I was missing other pitfalls...
For the record, I solved my Qt issues thanks to this :
http://qt-project.org/forums/viewthread/1690
by avoiding calls to QString::toStdString and QString::fromStdString as
described in the link.
The issue is not specific to 64bit builds.
I guess this info will be usefull for other OSGeo4W packagers wanting to
build a Qt app with VC2010 on top of the current Qt present in OSGeo4W.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/333#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
