[osgeo4w-dev] OSGeo4W Weekly report #6
Lord Flaubert Steve Ataucuri Cruz lord.ataucuri at ucsp.edu.pe
Fri Jul 26 16:09:34 PDT 2013
Hello
This is the weekly report for  week 6
*What did I do this week?*
  The main work in this week was around "downloading process" of license
file from server. I feel happy because, I finished the first version of
this new extend of Installer. So You can try it:
    - Download "setup.override.ini"  file  from "
http://trac.osgeo.org/osgeo4w/browser" in the root of your local directory
"C:\"
    - Download sources from server
http://trac.osgeo.org/osgeo4w/wiki/SetupDevelopment and follow the wiki in
order to build "setup.exe"
    - When you have the setup.exe run it
    -  Choose: Advance Install > Install from internet > Root Directory >
Local package directory > Direct connection
    - Choose a restrictive package for example "gdal-mrsid" or " gdal-ecw "
or both,  you should to choose these because I just created a files for
each one in download.osgeo.org server. If you choose another restrictive
package setup.exe will raise an error,  and choose another normal package
for example: "gdal-java".
    - The setup will download the license file from remote server into your
local directory "Local Package Directory" , you can see it If you want.
    - The next step setup.exe will load the file into a window and it will
show to user .
*What do I plan on doing next week?*
 I will improve some cases when there is no file in remote server and
install in "some path" that I will define with my mentor.
*Did I block on anything?*
*  I had resolved  many problems with segmentation fault. "segmentation
fault" when setup.exe does not found a license file in remote server.
I committed all my work at http://trac.osgeo.org/osgeo4w/timeline  from
1230-1233.  This is my work of this week.
[1] https://trac.osgeo.org/osgeo4w/changeset/1230
[2] https://trac.osgeo.org/osgeo4w/changeset/1231
[2] https://trac.osgeo.org/osgeo4w/changeset/1232
[2] https://trac.osgeo.org/osgeo4w/changeset/1233
Best Regards
Steve
Steve Ataucuri Cruz
School of Computer Science,
San Pablo Catholic University - Arequipa, Peru (http://www.ucsp.edu.pe),
Screen Names :
 stonescenter at hotmail.com (Windows Live Messenger)
 stonescenter at gmail.com (Google talk)
 stonescenter at yahoo.com (Yahoo Messenger)
 stonescenter (Skype)
+51.972529201 (Mobile)
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20130727/693e0dbe/attachment.html>
More information about the osgeo4w-dev mailing list
