[osgeo4w-dev] mapscript.py problem for qgis-dev
Gino Pirelli luipir at gmail.com
Mon Jun 17 11:38:03 PDT 2013
could be usefult the complete trace of the error on the new mapscript.py
Settings\Computer/.qgis2/python/plugins\rt_mapserver_exporter\mapfileexportdlg.py",
line 30, in
    import mapscript
  File "C:/OSGeo4W/apps/qgis-dev/./python\qgis\utils.py", line 453, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "C:\OSGeo4W\apps\Python27\lib\site-packages\mapscript.py", line 24, in
    _mapscript = swig_import_helper()
23, in swig_import_helper
    return _mod
UnboundLocalError: local variable '_mod' referenced before assignment
On 17 June 2013 20:25, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Luigi,
> Are you intentionally doing this with mapserver-dev and it's
> mapscript-python as opposed to the new mapscript-python package I prepared
> for MapServer 6.2 for you folks?  You may need to explicitly uninstall that
> old mapscript-python and mapserver-dev (which is now quite ancient).
> Best regards,
> Frank
> On Mon, Jun 17, 2013 at 10:43 AM, Gino Pirelli <luipir at gmail.com> wrote:
>> Hi, I'm Luigi Pirelli working for Faunalia.it (luigi.pirelli at faunalia.it)
>> execution a qgis-dev python plugin, I can't load mapscript.py module
>> due to lack fo DLLs. The problem is knows since 5 years:
>>    http://trac.osgeo.org/osgeo4w/ticket/26
>> so, I think that a problem related to an old win version...
>> Please let me know if there is a solution. Here is the log ot the tests I
>> did:
>> Changed 51 minutes ago by luigi.pirelli@…
>> First test with a clean QGIS master and mapscript OSGeo4W on a WinXP
>> Pro SP3 virtual machine.
>> Mapscript is mapscript-dev-python (5.2b3-1) installed in:
>> C:\OSGeo4W\apps\mapserver-dev\mapscript-python
>> Running plugin generate this error:
>> File "C:/OSGeo4W/apps/qgis-dev/./python\qgis\utils.py", line 454, in
>> _import
>> ImportError?: DLL load failed: The specified module could not be found.
>> Running Dependency Walker on _mapscript.pyd show the need of these
>> packages:
>> LIBMAP_DEV.DLL and PYTHON25.DLL
>> it's a OSGeo4W installer bug?
>> __________________________
>> comment:3 in reply to: ↑ 2Changed 15 minutes ago by luigi.pirelli@…
>> the same happend installing:
>> mapscript-python (5.0.2-1)
>> that is installed in: C:\OSGeo4W\apps\Python25\lib\site-packages
>> Running Dependency Walker results the same missing libraries
>> comment:4Changed 0 seconds ago by luigi.pirelli@…
>> TEST on: http://home.gdal.org/tmp/mapscript-python-6.2.1-2.tar.bz2
>> after cleaning of all mapscript available in C:\OSGeo4W I uncompressed
>> it (so installed mapscritp.py in
>> C:\OSGeo4W\apps\python27\lib\site-packages)
>> but obtained another error:
>> File "C:\OSGeo4W\apps\Python27\lib\site-packages\mapscript.py", line 23,
>> in
>> swig_import_helper
>> return _mod UnboundLocalError?: local variable '_mod' referenced
>> before assignment
>> so... no mapscript available seems to work with qgis-dev
>> osgeo4w-dev mailing list
>> osgeo4w-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
More information about the osgeo4w-dev mailing list
