[osgeo4w-dev] [osgeo4w] #392: sys.exec_prefix does not point to folder with pythonw.exe thus introducing inconsistency, e.g. with multiprocessing in QGIS plugins
OSGeo4W trac_osgeo4w at osgeo.org
Tue Nov 12 11:11:16 PST 2013
inconsistency,e.g. with multiprocessing in QGIS plugins
Reporter:  mlt     |        Owner:  osgeo4w-dev@…
    Type:  defect  |       Status:  closed
Priority:  major   |    Component:  Installer
 Version:          |   Resolution:  invalid
Keywords:  python  |
Comment(by jef):
 Replying to [comment:4 mlt]:
 > I wonder if there is a danger to pick up wrong python this way as there
 are common scenarios to have a few python installations and non-OSGeo4W
 may be on the PATH.
 OSGeo4W starts off a clean path.  So unless you explicitly add your
 pythons into PATH from within OSGeo4W you should be fine.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/392#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
