[osgeo4w-dev] [osgeo4w] #397: FFTW misses import library
OSGeo4W trac_osgeo4w at osgeo.org
Tue Nov 19 04:26:57 PST 2013
Reporter:  jmalik       |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |    Keywords:  fftw
Comment(by jmalik):
 work in progress...
 The following snippet generates the def and lib file.
 I did not test yet the resulting .lib
 call "C:\OSGeo4W64\bin\o4w_env.bat"
 set pf=%ProgramFiles(x86)%
 if "%pf%"=="" set pf=%ProgramFiles%
 call "%pf%\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" amd64
 set FFTW_DLL=%OSGEO4W_ROOT%\bin\libfftw3-3.dll
 set FFTW_IMPORTLIB=%~dp0\fftw3.lib
 set FFTW_DEF=%~dp0\fftw3.def
 for /F "delims=" %%i in ("%FFTW_DLL%") do set FFTW_BASENAME=%%~nxi
 echo LIBRARY %FFTW_BASENAME% > %FFTW_DEF%
 echo EXPORTS >> %FFTW_DEF%
 for /f "usebackq tokens=4,* delims=_ " %%i in (`dumpbin /exports
 "%FFTW_DLL%"`) do (
   if %%i==fftw echo %%i_%%j >> %FFTW_DEF%
   if %%i==dfftw echo %%i_%%j >> %FFTW_DEF%
   if %%i==DFFTW echo %%i_%%j >> %FFTW_DEF%
 lib /machine:x64 /def:%FFTW_DEF% /out:%FFTW_IMPORTLIB%
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/397#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
