[osgeo4w-dev] [osgeo4w] #370: QGIS 1.8 (x64) missing some GDAL raster tools in the Raster menu
OSGeo4W trac_osgeo4w at osgeo.org
Sun Sep 8 04:19:54 PDT 2013
Reporter:  saultdon   |        Owner:  osgeo4w-dev@…
    Type:  defect     |       Status:  reopened
Priority:  blocker    |    Component:  Package
 Version:             |   Resolution:
Keywords:  qgis, x64  |
Changes (by saultdon):
  * status:  closed => reopened
  * resolution:  invalid =>
Comment:
 Replying to [comment:3 Alister]:
 > Sorry, just to clarify: did you post it here because you did initially
 find this issue on Windows, and then later you found it on Arch as well?
 Yes, this was just for the Windows x64 installation only. But I did find
 it on Arch too so I didn't see a need to file a second bug report. I only
 referenced this bug report there because it outlines what was missing from
 the raster menu.
 The 32-bit OSGeo4W installer works out of the box, but the new 64-bit
 installer has this issue in QGIS 1.8.0 (but not master).
 You or someone else can close if they don't want to patch the QGIS 1.8.0
 in the new 64-bit installer and would rather wait till 2.0 comes out
 (whenever that is) but it would be nice to have a working raster menu in
 the stable version of QGIS for 64-bit Windows.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/370#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
