[osgeo4w-dev] Upgrade of GDAL 1.10.1 package
Tamas Szekeres szekerest at gmail.com
Thu Sep 26 12:51:24 PDT 2013
Mickaël,
Openjpeg support has already been added to the packages of
http://www.gisinternals.com/sdk/
You could also recompile GDAL using the -sdk packages from the site. Let me
know if you need something else.
Best regards,
Tamas
2013/9/26 SAVINAUD Mickaël <mickael.savinaud at c-s.fr>
> Hi,
> A colleague and myself can spend some times to upgrade the GDAL package
> (and add the support of openjpeg). We have started to use the vc9 script of
> Tamas Szekeres and try to use as output_dir the OSGEo4W one. However it
> seems not so easy ;)
> Could you please share with us the script or the documentation used to
> build the gdal package. With it we can upgrade the gdal package available
> into OsGeo4W and offer to QGIS a way to read JPEG2000 file with an
> efficient open-source solution (openjpeg).
> Best
> Mickaël
> This message was sent using IMP, the Internet Messaging Program.
> ______________________________**_________________
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/osgeo4w-dev<http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev>
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20130926/cf0800ba/attachment.html>
More information about the osgeo4w-dev mailing list
