[osgeo4w-dev] [osgeo4w] #413: add "Windows batchfiles for use with R" to OSGeo4W
trac_osgeo4w at osgeo.org
Sat Apr 5 11:57:56 PDT 2014
Reporter: hellik | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: major | Component: Package
Version: | Keywords: R
hi,
there are some nice simple windows-bat files [1] [2] to start R
(www.r-project.org) from everywhere if these bat-files are in %PATH%
tested here locally with following example
(A)
batch files are in e.g.
C:\OSGeo4W\apps\r-batchfiles
(B)
added a bat-file in
C:\OSGeo4W\etc\ini\r-project.bat
with a onliner to add (A) to the path
PATH %PATH%;%OSGEO4W_ROOT%\apps\r-batchfiles
then R is availabe in the OSGeo4W-shell/OSGeo4W-windows command shell and
can be started e.g. within a winGRASS-session.
as these R-batch-files recognizes R 32bit/R 64bit, it may be included in
OSGeo4W 32bit and 64bit.
the license is GNU GPL v2.
it would be a really added value for OSGeo4W, as R is often used in GIS
workflows/analyses and the OSGeo4W-R-integration would be enabled in an
easy way.
would it be possible these files into OSGeo4W?
thanks
Helmut
[1] https://code.google.com/p/batchfiles/
[2] http://cran.r-project.org/contrib/extra/batchfiles/
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/413>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
