[osgeo4w-dev] [osgeo4w] #179: Add Python RTree to OSGEO4W
trac_osgeo4w at osgeo.org
Mon Apr 7 08:56:48 PDT 2014
Reporter: davidfawcett | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: minor | Component: Package
Version: | Keywords: Rtree
Comment(by mlt):
I recently had to install rtree into OSGeo4W64 myself. Note that one can
install "properly" built python package EXEs with
%OSGEO4W_ROOT%\apps\Python27\Scripts\easy_install.exe without registering
OSGeo4W python. Also, if using OSGeo4W64, replace
rt = _load_library('spatialindex_c.dll', ctypes.cdll.LoadLibrary)
with
rt = _load_library('spatialindex_c-64.dll', ctypes.cdll.LoadLibrary)
around line 95 in core.py from rtree so OSGeo4W64 version of SpatialLib is
used instead of a bundled one that fails to load probably due to incorrect
mvc[rp]90.dll on the PATH.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/179#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
