[osgeo4w-dev] [osgeo4w] #399: [setuptools] easy_install fails with "failed to create process."
OSGeo4W trac_osgeo4w at osgeo.org
Tue Jan 7 11:05:51 PST 2014
Reporter:  saultdon  |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  major     |   Component:  Package
 Version:            |    Keywords:  setuptools
Comment(by jef):
 Replying to [comment:2 saultdon]:
 > Replying to [comment:1 jef]:
 > > Please provide sample output.
 I was thinking of something like:
 C:\OSGeo4W64>easy_install pypihello
 Searching for pypihello
 Reading https://pypi.python.org/simple/pypihello/
 Best match: pypiHello 1.2
 Downloading
 https://pypi.python.org/packages/source/p/pypiHello/pypiHello-1.2.zip#md5=01f698cfbdbb8c0b5494c54eb53b065a
 Processing pypiHello-1.2.zip
 Writing c:\users\jef~1.nor\appdata\local\temp\easy_install-
 i8hxfg\pypiHello-1.2\setup.cfg
 Running pypiHello-1.2\setup.py -q bdist_egg --dist-dir
 c:\users\jef~1.nor\appdata\local\temp\easy_install-i8hxfg\pypiHello-1.2
 \egg-dist-tmp-2eicvc
 zip_safe flag not set; analyzing archive contents...
 Adding pypihello 1.2 to easy-install.pth file
 Installed c:\osgeo4~1\apps\python27\lib\site-
 packages\pypihello-1.2-py2.7.egg
 Processing dependencies for pypihello
 Finished processing dependencies for pypihello
 C:\OSGeo4W64>
 As you can see it works fine here.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/399#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
