[osgeo4w-dev] [osgeo4w] #400: SAGA downgrades to 2.0.8 by default when installing or modifying installed packages
trac_osgeo4w at osgeo.org
Thu Jan 9 09:12:41 PST 2014
packages
Reporter: saultdon | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Installer
Version: | Keywords:
Comment(by saultdon):
But this is a bug relating to SAGA though and not QGIS.
When a user installs SAGA 2.1.0 (stable) the installer shouldn't be
forcing them back to 2.0.8 (legacy).
I don't really think SAGA (stable at 2.1.0) should be marked as "testing"
because that's actually the stable release and if the Processing
framework/plugin in QGIS isn't upgraded to the latest API changes than
that seems like a separate issue that the Processing Plugin maintainers
would have to address.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/400#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
