[osgeo4w-dev] [osgeo4w] #420: qgis-common.bat fails during postinstall
OSGeo4W trac_osgeo4w at osgeo.org
Mon Jul 7 01:48:35 PDT 2014
Reporter:  jphespanha  |        Owner:  osgeo4w-dev@…
    Type:  defect      |       Status:  closed
Priority:  major       |    Component:  Installer
 Version:              |   Resolution:  fixed
Keywords:              |
Comment(by jef):
 Replying to [comment:10 hellik]:
 > I've checked, both ms 64bit runtimes (2008, 2010) are installed on my
 box.
 Any more info if you run qgis-common.bat manually?  Did you check with
 depends and in the eventlog?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/420#comment:11>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
