[osgeo4w-dev] Source packages - Trying to do things right...
    Jürgen E. Fischer
    jef at norbit.de
    Mon Mar 31 08:03:11 PDT 2014
Hi Julien,
sorry for the late reply.
On Mon, 10. Mar 2014 at 10:20:49 +0100, Julien Malik wrote:
> Ok so I'll generate them as part of the source package recipe.
> > The idea was to eventually integrated that into the cgis, but I didn't do
> > it yet.
> cgis, what's this ?
http://upload.osgeo.org/cgi-bin/osgeo4w-regen.sh and co.
> >> I don't understand how the zlib recipe works. I fails on my system due to
> >> tar not accepting output file with backslahes in path.  I think I only
> >> have tar from the msys OSGeo4W package. Which one do you use for zlib ?
> > I used cygwin's tar.
> Ah.. OK. Too bad the tool is not provided by OSGeo4W itself.  Is there a
> chance this can be fixed ?
Not sure that msys tar can't be use to prepare packages - I'd avoid backslashes
in any case.
> >> - If there is one recipe you consider should be the model, for what
> >>   package is it ?
> > Not really.  My recipes evolved from package to package.  They probably
> > should include or download the actual source, be ready for automated
> > building, automatically install build dependencies (apt?) and stuff like
> > that.
> Cannot agree more.  Also, I was thinking it might be desirable to package
> some missing build tools directly into OSGeo4W.  We have swig or sip but
> don't even have cmake.
Well, I try to not package third party development tools - unless they are part
of what gets built (like sip).
> It seems to me we are really close to have an OSGeo4W build machine be "basic
> standard windows + OSGeo4W + vc10".  That would be great to turn this into a
> reality.
We are?  BTW I'd need vc8 too - well, if we can actually build everything
automatically that might obviously change.
> > Ideally it should handle both architectures too.
> Great idea too. Do you have an advice on that ?  I currently think the
> "package.cmd" bat file shall be run from an OSGeo4W shell and recognize the
> architecture flavor.  Is there any env var/tool in OSGeo4W shell telling the
> architecture ?
This would work:
python -c "import sys; print 'x86' if sys.maxsize <= 2**32 else 'x86_64'"
> > So for now they just have the character of elaborate build notes.
> > Also most if not all source packages are not correct for use with the
> > installer, because they just contain files that are meant to go into a
> > manually extracted source tree somewhere, while the installer would install
> > them into the osgeo4w tree where they would clash, because they would all
> > use the same directory 'osgeo4w'.  I think the sources should live in
> > /usr/src/$package/, but missed to check cygwin packages earlier and didn't
> > want to rebuild everything just to fix the source packages.
> That's what I did : source package extracts to /usr/src/osgeo4w/$package and
> generates build result in /usr/src/release/$package.  Easier for me then to
> script things to manage synchronisation from /usr/src/release to the osgeo
> server.
Yes, for most things I also put the stuff into a local repository.
> >> - Can you review the "glew" source package ?
> > Um, the archive contains backslashes in the path - that's IMHO undesireable.
> OK so I guess I should go for cygwin's tar.  However it does not seem to
> create issues for extracting the tarballs, even under linux shells.
On linux it didn't create subdirectories but files with backslashes in their
names.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev
