[osgeo4w-dev] [osgeo4w] #420: qgis-common.bat fails during postinstall
OSGeo4W trac_osgeo4w at osgeo.org
Tue May 27 09:05:43 PDT 2014
Reporter:  jphespanha  |       Owner:  osgeo4w-dev@…
    Type:  defect      |      Status:  new
Priority:  major       |   Component:  Installer
 Version:              |    Keywords:
Comment(by jphespanha):
 Replying to [comment:5 jef]:
 > Replying to [comment:4 jphespanha]:
 > > Sure that this path is OK?
 > > set QGIS_PREFIX_PATH=C:/OSGEO4~1/apps/qgis
 > You tell me. Doesn't "C:/OSGEO4~1/apps/qgis" take you to the qgis
 directory?
 > I suspect there is a side by side configuration error.  Please check
 eventlog is you can spot any, use [http://www.dependencywalker.com/
 dependency walker] find details about it.   I still think the server is
 just missing some ''Microsoft Visual C++ Redistributable Package''.  It
 would be nice if you could identify which particular one it is.
 There is no problem with the path. I just find it confusing; in windows
 should be "C:\OSGEO4~1\apps\qgis", but it works nevertheless.
 And you are right with the "SidebySide" error. I checked the application
 event log at the server, and spotted this message:
 "Activation context generation failed for "C:\OSGEO4~1\bin\SSLEAY32.dll".
 Dependent Assembly
 Microsoft.VC90.CRT,processorArchitecture="amd64",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8"
 could not be found. Please use sxstrace.exe for detailed diagnosis."
 I will try the "dependency walker", but maybe there is already sufficient
 info to solve the situation.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/420#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
