[osgeo4w-dev] [GRASS-user] Grass osgeo4w 64bit not working
Alex Mandel tech_dev at wildintellect.com
Thu Nov 20 10:34:18 PST 2014
Was experimental. It is just as stable as 32 bit now, just doesn't have
100% coverage of all the same packages (I think some web stuff is still
not 64bit). GRASS should be working. If it is not the place to report it
is the osgeo4w mailing list or the issue tracker
https://trac.osgeo.org/osgeo4w
Note, you can easily install both 32 and 64 bit on the same machine just
put them in different root folders.
Thanks,
Alex
On 11/20/2014 06:34 AM, Roy wrote:
> Hi Vaclav,
> thanks for you answer, i'll check on OSgeo4W site
> Il 20/11/2014 15.17, Vaclav Petras ha scritto:
>> On Thu, Nov 20, 2014 at 6:16 AM, Roy <royroge at outlook.com
>> <mailto:royroge at outlook.com>> wrote:
>>     Hi all,
>>     I'm trying to install GRASS 64bit using the osgeo64bit installer
>>     but the installed
>>     GRASS 6.4.3 is not working properly ang gives an error,
>>     something like:
>>     g.mapset.exe has stop working
>>     then the interface seems to start but i cannot load any raster data
>>     as the interface to dislpay raster does not show up:
>>     d.rast.exe has stop working
>>     any idea on how to solve this ?
>> I'm not sure what is the situation now but 64bit OSGeo4W was
>> experimental. The stable version was only 32bit. You should be able to
>> find more on OSGeo4W website [1] or mailing list [2]. Let us know you
>> progress.
>> FYI, you email was unfortunately marked as spam by Gmail.
> maybe Gmail does not like Outlook ;-)
> thanks and regardds,
> Roy.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
More information about the osgeo4w-dev mailing list
