[osgeo4w-dev] [osgeo4w] #293: update gdal dependencies (netcdf, hdf5)
OSGeo4W trac_osgeo4w at osgeo.org
Mon Oct 27 02:40:42 PDT 2014
Reporter:  jef    |       Owner:  osgeo4w-dev@…
    Type:  task   |      Status:  new
Priority:  major  |   Component:  Package
 Version:         |    Keywords:  netcdf4
Changes (by tdamsma):
  * keywords:  => netcdf4
Comment:
 I noticed that the gdalinfo packed in osgeo4w (both x86 and x64 version)
 does not correctly open some netcdf4 files I have, and uses the HDF5
 driver instead. (Even though netcdf library 4.3.0-1 is packaged in the
 current osgeo4w64 release). Using the gdalinfo installed via the
 unofficial python binaries distributed by the Laboratory for Fluorescence
 Dynamics of the University of California,
 (http://www.lfd.uci.edu/~gohlke/pythonlibs/#gdal) gdalinfo does work
 correctly on netcdf4 files.
 I think this has to do with the issue above, though not sure.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/293#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
