[osgeo4w-dev] Fwd: Unable to read data correctly in gdal python
Lucia Leon leoneslucia at gmail.com
Fri Apr 24 08:07:15 PDT 2015
Dear all:
I tried it with every kind of gdal binaries available: from Christoph
Gohlke, from Tamas Szekeres, and from Osgeo4w.
But all the gdal binaries report wrong dimension of the HDF dataset.
What should I do? Is the problem inherent to gdal source code?
Any of yours idea is appreciated.
Thanks.
Lucia
---------- Forwarded message ----------
Date: Thu, Apr 23, 2015 at 8:52 PM
Subject: Unable to read data correctly in gdal python
To: gdal-dev at lists.osgeo.org
Hello,
The gdalinfo.exe correctly shows the subdataset of a HDF4 file with
dimension [180x8x32x9].  But the same subdataset read from gdal in python
is only  [180x8x32].
I was using the gdal binary from Christoph Gohlke in windows, and according
to  him, the GDAL binaries are built with HDF-4.2.10:
http://www.lfd.uci.edu/~gohlke/pythonlibs/6icuform/GDAL-1.11.2-cp27-none-win_amd64.whl
The HDF4 file I was using is here:
ftp://l5eil01.larc.nasa.gov/MISR/MIL2ASLS.002/2011.07.04/MISR_AM1_AS_LAND_P233_O061399_F07_0022.hdf
The code I was using was as follows:
import gdal
from gdalconst import *
data = gdal.Open('HDF4_EOS:EOS_GRID:' + infile +
':RegParamsLnd:ViewZenAng', GA_ReadOnly).ReadAsArray()
print data.shape
I hope some of you can help me.
Lucia
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20150425/76f56fa4/attachment.html>
More information about the osgeo4w-dev mailing list
