[osgeo4w-dev] [osgeo4w] #471: OSGEO4W 64 Bit PDAL PLY-Reader fails
trac_osgeo4w at osgeo.org
Mon Aug 17 01:27:02 PDT 2015
Reporter: bma1 | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: 1.0 | Keywords: Pdal, ply-Reader
on my System (Windows 7)I get the error "PDAL: Error opening ply file:
aborted by user" for every ply-file I choose as Input.
Do you have an example for ply-reader is working ?
As an example I use the bunny-files from stanford University
(http://graphics.stanford.edu/data/3Dscanrep/)
and the following XML-File
<?xml version="1.0" encoding="utf-8"?>
<Pipeline version="1.0">
<Writer type="writers.text">
<Option name="filename">./bunny/reconstruction/test.txt</Option>
<Option name="cache_block_size">32184</Option>
<Reader type="readers.ply">
<Option
name="filename">./bunny/reconstruction/bun_zipper_res4.ply</Option>
</Reader>
</Writer>
</Pipeline>
I use the command pdal Pipeline bunny.xml.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/471>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
