[osgeo4w-dev] [Qgis-developer] Crash in thread on FILE opened by a lib compiled by MinGW
Jürgen E. Fischer
jef at norbit.de
Fri Jun 19 02:27:33 PDT 2015
Hi Radim,
On Fri, 19. Jun 2015 at 11:04:39 +0200, Radim Blazek wrote:
> I am trying to fix QGIS (compiled by MSVC) crashes with GRASS 7
> (compiled by MinGW) on Windows. I have traced down that it crashes
> when functions are called on a FILE structure which was created by a
> library (libgrass_gis.7.0.0.dll in this case) compiled by MinGW in a
> thread in an application compiled by MSVC. It crashes in Microsoft
> _lock_file(FILE *pf) where pf is casted to _FILEX:
Did you also track down what calls that?
Maybe something in QGIS that uses a file pointer function (fclose?) on
something returned from GRASS? There should be some G_ function to call
instead.
I remember there was something similar that happend when GRASS was using a MSVC
built libpng (not lock_file in particular, but mixing up msvcrt file pointers).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20150619/5cc57c6c/attachment.pgp>
More information about the osgeo4w-dev
