[osgeo4w-dev] [osgeo4w] #458: Generate setup.ini based on aribitrary date and/or time
trac_osgeo4w at osgeo.org
Sat Mar 7 02:28:50 PST 2015
Reporter: maphew | Owner: osgeo4w-dev@…
Type: enhancement | Status: closed
Priority: major | Component: Installer
Version: | Resolution: fixed
Keywords: setup.ini |
Changes (by jef):
* status: new => closed
* resolution: => fixed
Comment:
{{{genini}}} now has a {{{--date=yyyy-mm-dd}}} argument and ignores older
files.
{{{regen.sh}}} wasn't updated and you'll have to run genini manually like
this:
jef at download:~$ /osgeo/download/osgeo4w/genini --date=2015-03-01
--arch=x86 --recursive --output=old.ini
/osgeo/download/osgeo4w/x86/release
error: /osgeo/download/osgeo4w/x86/release/grass/grass71-dev/setup.hint:7:
can't open
/osgeo/download/osgeo4w/x86/release/grass/grass71-dev/grass71-dev-7.1.svn-r64718-1.tar.bz2
- No such file or directory
can't open
error: /osgeo/download/osgeo4w/x86/release/mapserver/mapserver-dev
/mapscript-java-dev/setup.hint:6: not enough package files in
/osgeo/download/osgeo4w/x86/release/mapserver/mapserver-dev/mapscript-
java-dev
/mapscript-python-dev/setup.hint:6: not enough package files in
python-dev
error: /osgeo/download/osgeo4w/x86/release/mapserver/mapserver-stable-dev
/mapscript-java-stable-dev/setup.hint:6: not enough package files in
/mapscript-python-stable-dev/setup.hint:6: not enough package files in
dev/setup.hint:7: not enough package files in
Note that that produces more entries like the one from #457, because that
apparently wasn't fixed yet and the nightly builds are cleaned up
regularly and there are no files left for older states.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/458#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
