[osgeo4w-dev] [osgeo4w] #484: The ordinal 3872 could not be located in the dynamic link library C:\OSGeo4W\bin\SSLEAY32.dll
OSGeo4W trac_osgeo4w at osgeo.org
Wed Feb 17 08:18:32 PST 2016
Reporter:  julienPX  |      Owner:  osgeo4w-dev@…
    Type:  defect    |     Status:  new
Priority:  major     |  Component:  Installer
 Version:            |   Keywords:  ordinal 3872
 Good afternoon,
 I try to use GEOS with Django and MySQL. I installed the program "osgeo4w-
 setup-x86.exe" (Express Web-GIS Install, then GDAL only as prescribed on
 the DjangoProject site) on my computer (Windows 8.1). I followed all
 instructions. The installation ended with no errors.
 I use the following versions:
 -       Python 2.7
 -       Django 1.8.9
 -       MySQL 5.5
 I defined my DATABASE like that in Django:
 DATABASES = {
     'default': {
         'ENGINE': 'django.db.backends.mysql',
         'NAME': 'myapp',
         'USER': 'root',
         'PASSWORD': 'mypassword',
         'HOST': '127.0.0.1',
         'PORT': '3306',
 I created the database myapp in mySQL.
 I set the environment variables like that :
 set OSGEO4W_ROOT=C:\OSGeo4W
 set PYTHON_ROOT=C:\Python27
 set GDAL_DATA=%OSGEO4W_ROOT%\share\gdal
 set PROJ_LIB=%OSGEO4W_ROOT%\share\proj
 set PATH=%PATH%;%PYTHON_ROOT%;%OSGEO4W_ROOT%\bin
 reg ADD "HKLM\SYSTEM\CurrentControlSet\Control\Session
 Manager\Environment" /v Path /t REG_EXPAND_SZ /f /d "%PATH%"
 Manager\Environment" /v GDAL_DATA /t REG_EXPAND_SZ /f /d "%GDAL_DATA%"
 Manager\Environment" /v PROJ_LIB /t REG_EXPAND_SZ /f /d "%PROJ_LIB%"
 When I start my app, I get a window with the following error:
 "The ordinal 3872 could not be located in the dynamic link library
 C:\OSGeo4W\bin\SSLEAY32.dll"
 I spent days trying to find an answer but nothing on the web. I tried to
 install PostgreSQL + PostGIS, reconfigured everything and got exactly the
 same error.
 Here is the end of setup.log.full in C:\OSGeo4W\var\log:
 C:\OSGeo4W>dllupdate -oite -copy -reboot "C:\OSGeo4W\bin\libeay32.dll"
 C:\OSGeo4W\bin\libeay32.dll: Version=1.0.1.7
 C:\WINDOWS\system32\libeay32.dll: Version=0.0.0.0 Target does not exist,
 no action.
 C:\OSGeo4W>dllupdate -oite -copy -reboot "C:\OSGeo4W\bin\ssleay32.dll"
 C:\OSGeo4W\bin\ssleay32.dll: Version=1.0.1.7
 C:\WINDOWS\system32\ssleay32.dll: Version=0.0.0.0
 Target does not exist, no action.
 Thanks a lot ! Any help would be really useful.
 Julien
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/484>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
