[osgeo4w-dev] [osgeo4w] #473: create a geos-c++ package
trac_osgeo4w at osgeo.org
Mon Jan 11 06:03:48 PST 2016
Reporter: rashadkm | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: |
Comment (by rashadkm):
recalling the discussion on geos-devel list;
geos c++ api is fully supported and can be used if the project wants to.
So ossim is using it without any violation. It is not a serious bug is
ossim that it uses geos c++. Why should the package upgrade be blocked
because of ossim using geos c api. If there comes a problem because of
geos-c++ api, the other packages must be given a clear documentation
somewhere in osgeo4w page or atleast even try to cope with the issue. Not
the other way around. Only to include a package in osgeo4w, the upstream
should rewrite a part of its code which is working and is not a violation
of anything that osgeo4w stands for.
Imagine if ossim someday decides to move to geos c api. the there comes
otb that uses ossim c++ api. And unfortunately, there is no C api for
ossim. So the packaging blocked.
Is the osgeo4w packages are specific to C projects. I never know. I am
completely lost on this point. All I get was a humble request to move to c
api?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/473#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
