[osgeo4w-dev] [osgeo4w] #513: JP2MrSID support missing from latest version of gdal-mrsid?
trac_osgeo4w at osgeo.org
Tue Jun 28 16:00:35 PDT 2016
Reporter: ogcr | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: blocker | Component: Package
Version: | Keywords: gdal-mrsid jp2mrsid
Using the OSGeo4W 32bit installer, I've installed the latest "cur" version
of gdal, gdal-mrsid, and dependencies that the installer will allow me to
(excepting gdal-dev). `gdalinfo --formats` reveals that mrsid support is
loaded and working, however jp2mrsid support is missing. Partial output
below:
C:\OSGeo4W3\bin>gdalinfo.exe --version
GDAL 2.1.0, released 2016/04/25
C:\OSGeo4W3\bin>gdalinfo.exe --formats
Supported Formats:
MG4Lidar -raster- (ro): MrSID Generation 4 / Lidar (.sid)
MrSID -raster- (rov): Multi-resolution Seamless Image Database (MrSID)
VRT -raster- (rw+v): Virtual Raster
GTiff -raster- (rw+vs): GeoTIFF
NITF -raster- (rw+vs): National Imagery Transmission Format
--snip--
If I install a previous version (1.9.2) of gdal, gdal-mrsid, and
dependencies, mrsid and jp2mrsid formats appear as desired in gdalinfo:
C:\OSGeo4W2\bin>gdalinfo.exe --version
GDAL 1.9.2, released 2012/10/08
C:\OSGeo4W2\bin>gdalinfo.exe --formats
Supported Formats:
MG4Lidar (ro): MrSID Generation 4 / Lidar (.sid)
MrSID (rov): Multi-resolution Seamless Image Database (MrSID)
JP2MrSID (rov): MrSID JPEG2000
VRT (rw+v): Virtual Raster
GTiff (rw+v): GeoTIFF
NITF (rw+v): National Imagery Transmission Format
--snip--
I also tried the "exp" and the "dev" versions of the "exp" packages, and
ended up with the same result of missing JP2MrSID support, but I've
omitted the output for the sake of brevity.
Is there a particular reason that JP2MrSID is missing, or am I simply
overlooking something obvious? I'm guessing the latter, but I've searched
everywhere to see why the support would be removed, or how to enable it
some other way, and have come up empty-handed.
GDAL_SKIP of other JP2 drivers seems to have no effect (other than
disabling other JP2 drivers) in any case.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/513>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
