[osgeo4w-dev] [osgeo4w] #529: Add gdal_array to python3-gdal
trac_osgeo4w at osgeo.org
Fri Apr 21 00:49:44 PDT 2017
Reporter: hmercier | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: |
Comment (by hmercier):
Ok, thanks.
For information, I noticed there is a python3-gdal-dev package here :
http://download.osgeo.org/osgeo4w/x86_64/release/gdal/gdal-dev/python3
-gdal-dev/ (without setup.hint so not available through the installer).
I manually installed it and python3 crashes when doing "from osgeo import
gdal_array".
From what I can see, python3-gdal-dev is compiled with MSVC2015 and GDAL
with MSVC2010, which I guess should be the root of the problem (?). I had
the same problem on a manual compilation of python3-gdal with MSVC2015.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/529#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
