[osgeo4w-dev] [osgeo4w] #551: libnetcdf 4.4.1.1 crashes on netcdf v4 files with attributes of type string
trac_osgeo4w at osgeo.org
Mon Dec 11 10:42:59 PST 2017
Reporter: rouault | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords:
From https://trac.osgeo.org/gdal/ticket/7172
There is a crash specific to the latest netcdf version in OSGeo4W
(4.4.1.1), but cannot be reproduced with the previous one (4.3.0). It is
also specific of netcdf v4 files that have at least one attribute of type
"string"
Given test.c
#include <netcdf.h>
int main(int argc, char* argv[])
int cdfid = -1;
nc_open(argv[1], NC_NOWRITE, &cdfid);
nc_close(cdfid);
return 0;
compiled with "cl minimal.c /Ie:\osgeo4W64\include
e:\OSGeo4W64\lib\netcdf.lib" (with VS 2015 64bit) and minimal.nc
(attached) being a netcdf 4 file with just a variable of type string
$ ncdump /tmp/minimum.nc
netcdf minimum {
// global attributes:
string :Conventions = "CF-1.6" ;
"minimum.exe minimal.nc" crashes. DrMemory output is
Error #1: INVALID HEAP ARGUMENT to free 0x00000000029c2830
# 0 replace_free
[d:\drmemory_package\common\alloc_replace.c:2706]
# 1 hdf5.dll!H5Aexists +0xf8 (0x000007fef3219b59
<hdf5.dll+0x9b59>)
# 2 hdf5.dll!H5I_dec_ref +0xaf (0x000007fef339f600
<hdf5.dll+0x18f600>)
# 3 netcdf.dll!nc_set_var_chunk_cache_ints +0x9695 (0x000007feee823f86
<netcdf.dll+0x43f86>)
# 4 netcdf.dll!NC4_sync +0xb9d (0x000007feee814a2e
<netcdf.dll+0x34a2e>)
# 5 netcdf.dll!nc_set_var_chunk_cache_ints +0x215 (0x000007feee81ab06
<netcdf.dll+0x3ab06>)
# 6 netcdf.dll!cdRel2Iso +0x41d (0x000007feee7f073e
<netcdf.dll+0x1073e>)
# 7 netcdf.dll!nc_set_var_chunk_cache_ints +0x146b (0x000007feee81bd5c
<netcdf.dll+0x3bd5c>)
# 8 netcdf.dll!nc_set_var_chunk_cache_ints +0xe99 (0x000007feee81b78a
<netcdf.dll+0x3b78a>)
# 9 netcdf.dll!NC4_sync +0xab (0x000007feee813f3c
<netcdf.dll+0x33f3c>)
#10 netcdf.dll!NC4_close +0x3c (0x000007feee813aed
<netcdf.dll+0x33aed>)
#11 netcdf.dll!nc_close +0x23 (0x000007feee7e2994
<netcdf.dll+0x2994>)
#12 minimal.exe!? +0x0 (0x000000013f32103c
<minimal.exe+0x103c>)
#13 minimal.exe!? +0x0 (0x000000013f321255
<minimal.exe+0x1255>)
#14 KERNEL32.dll!BaseThreadInitThunk +0xc (0x0000000077a3652d
<KERNEL32.dll+0x1652d>)
Note: @0:00:00.491 in thread 3780
Note: refers to -7 byte(s) beyond last valid byte in prior malloc
Note: prev lower malloc: 0x00000000029c2830-0x00000000029c2837
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/551>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
