[osgeo4w-dev] [osgeo4w] #550: OSGeo4W-64 bit: lasinfo crashes with an entry point not found
trac_osgeo4w at osgeo.org
Thu Dec 14 10:08:10 PST 2017
Reporter: hellik | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Resolution:
Keywords: las |
Comment (by hellik):
Replying to [comment:2 hobu]:
> This was caused by me. I updated LASzip, but libLAS hasn't been updated
to use the new LASzip API. You'll have to revert to the LASzip 2.2.0
version to use libLAS
it's possible to downgrade manually, but osgeo4w will download latest
version.
e.g. GRASS GIS uses OSGeo4W as build environment. build environment can be
downgraded.
but everytime a user updates his OSGeo4W stack, the GRASS lidar modules
and eventually QGIS (e.g GRASS lidar commands in procesing) will be likely
broken on runtime.
no chance to fix the broken liblas/laszip stack?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/550#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
